Grover70
- Ponte Vedra, FL
- FSH Deluxe
I was hoping for some information about a particular pump and some ideas of where to clamp off the intake in the FSH in the event of towing:
Is this the pump that brings in water for the live well?
The pipe is pretty narrow here and I'd like to be able to clamp it in the event, however unlikely, I need to be towed. Should I replace this tube with a slightly longer one or is there another location I can clamp it? I noticed in another thread on a different Yamaha that someone added an inline shut off. Recommendations?
If this is the pipe that brings in water for the wash down, does it go to a pump out of sight and then to the wash down hose? Or does it use engine "suction"? I was thinking of placing the hose into the casting net storage area for a potential fresh water tank location. I know about using a separate wash down pump that Out on the Reef used but I was thinking of branching off the existing hose to a fresh water tank in the casting net storage.
Thanks guys! I always get great ideas here.
