jtwrace
- Orlando, FL
- Other
- PWC
Here is my oil change using Blackstone Labs for analysis with AMSOIL INC 10W-40 Marine in a Yamaha 1.8L
* My first oil change was at 5 hrs using Yamalube and then at 10 hrs which I then switched to Amsoil. All oil changes have used the OEM Oil Filter as shown.
** Just to note I have used Ethanol Free Gas exclusively and have used Sta-Bil Marine 360 in every top off.
As you can see from the photos of the filter, there are small ( > 20 micron) aluminum specs. Nothing to be concerned about as it's normal and the oil concludes that as well.
For those that are curious, it's $28 for the oil analysis. This is very common in Aerospace and many other industries so I'm not that far off...well, OK, maybe a little but it's my world.
Blackstone Laboratories | Oil Analysis - Learn What's Going On In Your Engine
https://www.amsoil.com/shop/by-produ...?code=WCFQT-EA
***After me studying the first report, I requested a retest of the fuel content which is the reason for the amended report. The Flashpoint temp as 380°F, just barely above the “should be “ value of >375°F. Amsoil begins with a Flashpoint temp of 464°F when new, fuel dilution is the only means that the Flashpoint temp could be reduced by 84°F. This would be more than enough fuel dilution to reduce the viscosity to the 30-weight range.
