Maineiac
- Iowa
Over the weekend we were out on the boat all day and I noticed some water pooling at the bottom of the locker, most likely from the toys we had put away. I thought this was no big deal and opened the drain plug at the bottom of the ski locker to let the water drain out. Instead of draining, it started FILLING with water from below!
I assume this means my bilge was full? When I put the boat back on the trailer, a LOT of water drained out of the plug. There was still a slow trickle of water after driving 10 miles back to the storage place I keep the boat.
I did some quick checking for leaks and noticed that the plastic cover that attaches to the hull in the clean out compartment isn’t fully attached. The screw in one corner is stripped and isn’t fastened to the hull. There’s a screw there but I can lift up that corner with my hand. I tried tightening it but it just spins.
Could this be my problem?
