Water coming in engine compartment
Melissa Hall
We have a 2018 190 FSH sport that water is coming into Compartment . does anyone know what may be causing this?
Acard7
SW Iowa
Open it up while on the water and see if you can see anything leaking while it’s running. There’s a section in the FAQ section of the page about leaks you should take a look at:
Finding a Leak
CaptRedbeard
Omaha, NE
One starting point I'd suggest is deciphering whether it's warm water (engine coolant leak) or cold water (hull leak, etc) in the bilge.
