Ilmmct
- Wilmington, NC 28411
- Limited S
I have a 2013 242 Limited S that I am doing my first flush procedure. The Starboard side has a solid and healthy flow from the flush kit to the trusters. The Port side seems to not have enough of the water escaping from the trusters. Some water is coming out of the the intake grates, but compared to the Starboard side the flow seems very weak. I removed the hatch separting the firewall and everything looks connected up well and there are no leaks of the flush line.
Any ideas would be appreciated. I did not run the engine long, shut this down until I get some advice and someone that can look at the rear of the boat and water flow before I start the procedure up again.
