Nikokrzynowek
- Connecticut
Back story on the boat. Just bought the boat a month ago. Was told it has been sitting since 2018 on a trailer and hasn’t been touched since. Prior to that the boat was moored at a marina on a fresh water river. The end of the season of 2018 the owner was having issues with one engine getting rpm up, said he believes the Intake grate just needed to be siliconed. Pulled apart both, ended up doing new impellers sleeves and bearings. Reassembled then I figured I’d warm up the engines to change the oil and plugs. Checked oil level on both sticks. Oil looked good was just on the low side of the stick. Started the port side engine, turned water on and within a few seconds the oil pressure light came on. I shut off the water supply then killed the engine. Checked the dipstick and it was full of water. I have not started the starboard side engine yet. I figured maybe the boat wasn’t properly winterized and water froze somewhere and cracked something. I believe both engines would have the same issue so today I removed both engines. Attached are photos of port and starboard engines during the dissambly. I cannot for the life of me find anything. I don’t see any visible external cracks on the blocks. On disassembly of the port engine everything was white milky. No water or oil in cylinders. The water ports on the manifold and heads look perfect no corrosion or pin holes or broken spots like I’ve seen here on the forum. No cracks above the starter. Only thing I noticed was when I pulled the oil cooler off the starboard engine the ground flooded with oil with water in. Anyone have any ideas on what could have happened? Where water sits in the engine / cooler if it wasn’t properly flushed for the winter. What typically cracks on these if not properly winterized. Just trying to narrow down where the issue could be before I start spending excessive money at the machine shop to pressure test everything and start rebuilding everything. Thank you guys any info is much appreciated. I’m new to the Yamaha jet boat world. Always had a inboard outboard bow riders
