scokill
- Rowlett, TX
So I've been taking on a little water....nothing out of the ordinary as the bilge pumps out water every now and then. I've chalked it up to water coming over the swim platform, but the other day we were docked and had more water than usual. I had already replaced the drain assembly this year and the scupper last year as they were leaking when filled up with water.
So I removed the cleanout tray and filled the back up with water. At first there was nothing and I was relieved but shaking my head. Then a constant trickle started coming out of the scupper.... not around it like a cracked housing, which wasn't likely since I replaced with stainless, nor around like a bad installation, but through the hose and out the flapper.
So my thought is one of two things...either the drain hose has a hole in it or I don't have it fully seated around the scupper. The hose appears to be on good and the clamp is very tight. So could the water come in the flapper and leak into the boat if there is a hole in the hose??? Just seeing if there are other thoughts.
