kgower
- Buford, GA
- 222SE
I recently picked up a pair of Revo 6's. I have never installed speakers with RGB lighting, The manual says to connect the black wire using a 2amp inline fuse to 12V positive. red, blue and green can be connected together to ground.
I will eventually replace the mid-cabin and bow speakers with Revo 6's as well (24 222SE) but will start with the transom.
A couple of questions, #'1 &2 I think I know, but want to confirm.
1. Will I have to widen the opening when replacing the recons with the Revo's?
2. Should I be able to just hook the speakers to the amp using the existing wire/harness?
3. Can the 4 RGB wires be connected to a fuse block?
4. Will I need to retune the amp on the appropriate channel?
TIA
TIA
