Wet Sounds T top speakers
Van T
Chesapeake va
First let me tell you what a pain in the butt it is to run speaker wires on a FSH 190 hidden inside the T-top tubes I ran insulated 4-wire up both sides so I can have two wires for each speakers and two wires for a front light two wires for a back light. You would think how much wet sounds rev 8 are they could make them Wireless or something I was going to run the wire outside of the tube, wet sounds rev 8 brackets are the wire goes to the middle of the bracket and it has to go through the tubes. It's just going to take longer than I anticipated better be worth it they sounded good when I hook them up last summer I'm just now finally getting them up.
