What is this unused hose fitting on top of jet nozzle (‘09 AR210))
Dfred
Fairfax Virginia
Noticed this hose fitting atop the nozzle connected to nothing ... upon closer inspection when nozzle was taken off - found it is closed off by solid metal. But it has a well or scoop inside the jet that would direct water into it, and it could be opened/drilled out? It’s a tad under 3/4” diameter.... could it be an option to use jet to fill ballast or wash down? I scoured the manuals and parts diagrams, and found nothing. E938A8B9-FD9F-4AB4-9865-FBFD15D759D8.jpeg5B264241-8912-4F32-9AE2-6A73BA027DB0.jpeg
It’s closed off from manufacturing, but there is a scoop molded in for it?
