thegrapeguy
- Syracuse, NY
- Other
2014 212x - I have read in great detail all I could about throttle issues. Basically I forget which throttle I have the drop issue on but I have the throttle drop issue. When I align the RPM's on the 2 engines and hit cruise assist one throttle drops back misaligning the RPM between engines. It's a small amount of RPM difference. I also notice that most times my throttles are an 1/8 to 1/4" off when I'm just in a straight line cruise with manual throttling.
So the throttle adjustments I have read about are:
1. Tension screws
2. Cable adjustments on sides of engine compartments
3. Engine cable connection at air filter box ( ? - couldn't quite understand this one)
4. Throttle drop fix
5. Using JetBoatPilot's throttle sync
6. Perfect Pass (for aiding wake boarding speeds) - cruise assist was ineffective to a degree as rider pull would affect boat speed AND boat would usually speed up to a speed greater than the wakeboarder wanted
My question what order should I go in to fine tune my throttles so I can boat and tow with solid even throttling.
I'm committed to the JBP throttle sync simply because it will make things easy especially for "guest" drivers who don't get the "match throttles" concept...
1. Tension screws
