Where does this hose drain?
Dodi5
When opening the engine compartment on the top ledge there is a drain hole , connected to what looks like a clear garden hose, it seems like it’s trying to drain into the wet storage area , can anyone confirm that? Thanks.
That's a drain hose for the engine hatch drain channel thing, it eventually runs through the transom and out on most models. Not sure exactly on yours, it may tie into a couple other lines on its way back.
Some models it may tie into a weep hole located behind some upholstery, above the clean out ports.
But not into the engine bay to the bilge pump.
Thanks I’ll check a bit more into it, and post pics , if someone has my same boat
