Welcome to Jetboaters.net!
If you have enough water pressure/flow it will come out the pee hole if you rev it up some. I don't have enough at home but at my marina I get some out of the pee holes.
Is that one season? It is a good idea to lube the plug cap seal with some silicon or dielectric grease to keep the moisture out. I just changed my plugs after 4 seasons and they looked as new as the ones I put in.
With tow valves installed (and shut) you can get the water to come of the pee holes while on the garden hose, just like in the water. Cam.
I'm not 100% sure but I believe that the 2005 models don't have Coil Over Plugs which help seal out a lot of the moisture that the plugs are subjected to. But it helps to put some dielectric grease on the plug wires and the plugs. Also, changing them annually will help you keep an eye on them.
