Yamaha 242 no power to gauges port side and motor won’t turn over.
Taylor0118!
So I’ve got a new issue on my 2014 Yamaha 242 Limited S..
When I turn over the ignition on the port side motor I get nothing.. The gauges don’t light up and the engine won’t even try to turn over. It’s almost as if I’m not even turning the key over. Before we start this is what I’ve done so far. Swapped the ignition switches from port to starboard, same issue.. nothing. Replaced the starter relay, nothing…checked all known fuses and replaced battery. Still nothing. I can turn over the starter by connecting a jumper from the battery straight to the starter. So the starter is good, ignition switch is good, fuses are good, relay switch is good.. any advice on what I’m missing. Seems like it’s an electric issue but I can’t seem to figure out where.. thanks in advance!
