Spincycle76
- Other
- Other
I replaced the bearings and seals on my boat trailer last summer, and found there was pitting pretty bad on the front axle. I am planning to replace it and the other axle, as I want the newer grease system and hubs and axles that are going to give me the best performance. I have had the issues since I bought the boat of it vibrating at speed for a bit and then nothing for a while, and am thinking it is the axle.
So I measured the axle and found hub face to hub face is 93-3/4", Spring center to spring center is 74", brake flange to brake flange is 87-7/8", 6"spring outside edge to the brake flange and 3" from the brake flange to the hub face. I have not found any axles that measure like this. I would find it a bit hard to believe this is a custom axle, as I would think that for manufacture they would want to keep them at a common size. Am I measuring something wrong? Has anyone replaced the axle, and if so can you let me know what you purchased? At close to 500 bucks for a custom axle I don't want to get the sizing wrong.
