Retired Greg
Check starboard engine warning time today while on the bayou. Luckily close to the dock and trailered easy with the other engine.
Hooked up the hose to flush and diagnose in the driveway and same warning lights up. Before cranking, I notice that when the water is running it flows out the side port easy and normal. When I crank, the warning comes on after about 10 seconds but I am noticing a much reduced flow out of the side port. At first, it was a trickle and now it’s slightly more but definitely not what I assess to be a healthy flow.
Understand the proprietary nature of Yamaha’s check engine diagnosis and I’ll reluctantly take it in if needed, but I’m hoping someone has experienced this before and has a couple of techniques to check out which may fix the glitch.
First run of the season, flushed and ran fine last weekend for the preseason checkout. Engine ran for a good 5-10 minutes with no issues before we pulled into our hang out spot. No prior issues with either engine, or the boat overall for that matter.
thanks much!!
-Greg
thanks much!!
-Greg
