chamilton89
- SeaDoo
- Jet Ski
- PWC
II need an MR1 expert. I am working on a 2014 Yamaha VX Deluxe for a friend. I have worked on a ton of Sea-Doos but have less experience on these MR1 engines. My friend said they were riding and suddenly lost power and started smoking really bad. Pulled the seat and cylinder 4 spark plug well was full of oil and had blown the coil pack out spraying oil everywhere. This also melted that coil pack.
This is how I got it, after it sat for a year like this. Since I got it, I have replaced all the plugs, got a new coil pack, and replaced the damaged valve cover gasket that had let go letting oil into #4 spark plug well. Topped off the oil as well and it runs fine.
Ran it on the water for around a half hour and had zero issues, full RPM, no smoke. Got it back on the trailer and pulled the seat to find more oil in the bilge (fair amount, not a drip). Traced the oil leak back to the valve cover gasket that I had just replaced. Had blown right on the semicircle part of the gasket that covers the end of the cam, so that can be fixed easily.
My question is this. Originally I thought the gasket just let go and created all of the original issues that parked the ski. Now im really not sure. One second look, my friend told me it smoked like crazy when it dropped a cylinder and had the big oil leak. Now that the gasket has blown a second time, I am thinking I have a pressure issue inside that valve cover. Now I don’t know the dry sump oil system that well because normally I would just look for a clogged PCV. Why would excess pressure be trapped in the valvetrain causing that gasket to blow? I know there is a return that feeds back to the intake to burn that excess oil. So where do I start? Clogged hose? Too much oil? Any help would be greatly appreciated!
