Yamaha SX230 Mooring Cover
Foxfloat50
Does anyone know if there is an OEM Mooring Cover for a 2006 SX230 equipped with a wake tower OR will the AR230 mooring cover fit?? Thanks
An sx230 with an oem tower is an ar230. If your tower has the same number of mounting points and they are located in the same place as an oem tower the ar230 cover will fit. If not I recommend that you have your sx cover modified by a marine upholsterer.
Thanks Ronnie. I looked at it and it appears to be attached in a different way from the AR230. So I should probably buy a SX230 cover and have modified.
We got an SX cover and had it modified to fit our tower. It was harder to find someone to do the work than I would have thought though.
