- Florida
- Other
- Other
No and that is just poor quality control they should have checked it at the couplers it is obvious if they are not aligned correctly. If they have to replace the intermediate bearing assembly that is a bigger problem as the engine has to be moved forward and the pump pulled so the assembly can be replaced , if they don't replace it and the seals were damaged by the misaligned engine you will probably be doing it sooner than later.
