Any tricks for getting fuel tank access panel off??
Weebs74
Kailua, Hawaii
Thanks s
If you are ok with not fixing them all, I printed some caps that look way better than an empty hole. Hopefully you can fix them, but if you find that is not worth it, I could send you some caps to cover the holes.
Thanks so much for the idea. I will try and give it a go when I get back....currently stuck in Africa for a few more months.
Weebs74
Kailua, Hawaii
Those look awesome. I will def need to order some of those!!
If there is enough bolt left these work like a charm after soaking the bolts overnight in penetrating lubricant.
sidney
What size is bit and where to get one???
Might need to remove to replace floor drain…
Bruce
Royal, AR
zipper
Boston Whaler
