Intermediate Bearing greasing
Hellacool
I know discussed in nauseum. Basically I never had this done or did it. I am at 6 years and no issues. So, should I now grease it or leave it be? I see so much about never doing it and see people who do it. Almost seems the risk of doing it wrong can be bad. I am doing my yearly maintenance and now realize this was never done. My dealer never told me about the 10 hour.
Cobra Jet Steering LLC
Vendor
Florida
do a search, I posted how to add gear lube to it so you do not damage it.
sunbyrned
Louisville, KY
I would like to know too. I’m thinking though that he’s slipping the syringe between the gasket and the bearing housing. That’s where any extra grease would come out if too much is pumped in through the zirk. Don’t do anything until this is confirmed though. I’m watching.
Hellacool
I read every post I could find and what I am reading is simply remove the fitting, use some weed eater string to check the condition of the grease in that space then simply use a syringe to add grease and put the fitting back on. This method appears to remove the ability to over pressurize the space killing your seals. With the fitting removed, there is now a place for pressure relief. I am going to try this method.
sunbyrned
Louisville, KY
Ah! That makes better sense. I bet you’re right.
Hellacool
Well famous last words :) But I can not see how this method would hurt. At the least I do not have a 100% perfect amount of grease in the space but I think I would rather under grease than kill my seals. My only concern is killing the fitting somehow.
sunbyrned
Louisville, KY
I’ve done it with a gun for my 10 hour service on a rebuilt engine. It was suppose to get 30 CC’s, which I was able to determine each pump for my gun produced 1 CC. So, 30 pumps, right? After I did it it dawned on me that the bearings were not part of the engine rebuild and started to worry. A little bit (about a pump’s worth) came out of the seal. This was three years ago. So, based on that obvious over pumping and nothing happened, I think you’re safe to use the gun even but maybe just a few pumps. I do like the syringe idea though.
Vendor
Florida
Remove the fitting add the gear lube using the plastic syringe then reattach the fitting or replace it with a hose barb type they use to place the hose on the bearing housing then fold over the hose to close it off or plug the end with another fitting like they did in the original setup. This works excellent and having gear lube in it really lubes it better.
Hellacool
Are you mixing the gear lube with the grease or straight gear lube? Ratio?
Hellacool
Since I have never greased these, I will try the syringe method and see. Would hate to mess something up.
Vendor
Florida
way over thinking this, just add the gear lube.
Hellacool
I have no grease in there that I know of so I am assuming I need to get it greased first then use the gear lube during services. I was just not sure if you are only running gear lube, no grease, a combination etc.
Babin Farms
Lower Alabama
There is already grease in there even if you have not greased it, just add regular ol gear lube.
ripler
Just south of Pittsburgh
MasterCraft
I greased mine every time I winterized. My method was to pump the grease through the zerk fitting until the hose got firm, then using a small screwdriver I would push down on the ball on the zerk fitting until no grease came out, this was to relieve any pressure. I did it this way for the 10 years I owned my Yamaha.
Hellacool
I have no hose so I have to use the force. Step one is pull the zerk and check grease condition.
Sean R
Acworth GA
212S
How long are your guys arms? That zerk is down there. my 212 has a hose mounted to the top of the eng attached to the zerk. I add a few pumps every oil change, only two so far but the 100hr service is 20 hrs away. I had a Ar190 before did the same but now y'all got me nervous.
