- Royal, AR
- SX
This is a block that fits inside the dash to prevent the key switches rotating and a pair of washers to use on the front side to stop the key switch nuts from jumping threads when tightened against the curved dash plate.
The large block will be in various colors and is installed the dash so not seen. I can provide the washers in black or blue. Please message if you have a preference.
This is a updated design that should eliminate fitment issues from variation in the holes cut for the key switches.
More info is in this thread Fixed the rotating key switch issue. 2007 - 2009 SX230, AR230, 232 Limited
To order click the "Buy now" button in the top right corner or click on this sentence which will take you to PayPal.
