1995 Mirage steering bolt/fastener
ruben59
Sugar Sand
Mirage
Looking for the bolt/fastener that connects the steering cable to the nozzle on a Sportjet 120 installed in a 16 foot Mirage. I have been looking at parts catalogues for the Sportjet120 and they do not show this piece. Any ideas?
ruben59
Sugar Sand
Mirage
Must be an answer..Mercury books show everything except this fastener. It is special, not just a bolt. Just not sure why the IPC would not show it.
Cobra Jet Steering LLC
Vendor
Florida
post a picture of it if possible
Vendor
Florida
it is probably either a quick release ball and socket or a spherical end
Vendor
Florida
1708208634164.png it is a spherical end that screws on to your cable and a shoulder bolt that screws into the hole in the nozzle arm if you know the threads of the cable and the size of the hole in the nozzle you can order them on line by size
or go here and pay through the nose https://www.google.com/aclk?sa=l&ai=DChcSEwjx9JWItLOEAxX3oFoFHTSuC8cYABAcGgJ2dQ&ase=2&gclid=Cj0KCQiAz8GuBhCxARIsAOpzk8xjQ10y-bw0oSUGxgDFaqWdHsoQ7k991lPt3gqqXvSFCK2Du_2XxFEaAoSYEALw_wcB&sig=AOD64_2ieOAZZicN-6UB7msjzrwJvh2s3g&ctype=5&q=&nis=4&ved=2ahUKEwjJoo-ItLOEAxU2fTABHZWACXIQ9aACKAB6BQgDEJQB&adurl=
ruben59
Sugar Sand
Mirage
It is the shoulder bolt that I am missing. Thanks for the reply. I am not paying $70.00 USD for a bolt. My initial thought was just figure it out. Then I thought it is only a bolt..how bad could it be for OEM..pretty bad.
Vendor
Florida
show a picture of it if possible I usually have good ideas on how to make something work even if you do it a different way, more than 1 way to fix a steering cable.
