- Royal, AR
- SX
@Scottintexas would you like to be the guinea pig for a 3d printed replacement?
Sure if it's something that you're interested in trying and is easy, if not I don't mind ordering, I'm in no rush,@Scottintexas would you like to be the guinea pig for a 3d printed replacement?
I actually had looked at that site and saw CAD over on the right side and thought it was wanting Canadian dollars and wasn't going to entertain thatFound this... PSF (Inch) Flanged Sleeve Linear Plain Bearing $10.97
I need to test longevity but these provide greater precision and smoother operation than the metal bushings.
View attachment 123394View attachment 123395View attachment 123396
Got a part number and vendor in those plastic ones? I'll gladly pickup a set to test as well.@Scottintexas has a pair. I am hoping he will test them and let us know how they hold up. I have had one in for about a hundred miles, perhaps 4 hours of running. Seems to be holding up so far.
The vendor is @Bruce , he printed them. This is the one Scott was looking for earlier in the thread. It requires a little drilling out to fit. Bruce designed/made the plastic ones to fit without modifications. I too, could Beta test some bushings. Awaiting Feedback, before I buy aluminum/modify.Got a part number and vendor in those plastic ones? I'll gladly pickup a set to test as well.
It would be interesting to compare your measurements to mine.Thanks @zipper
Did Yamaha really drill these out to some oddball dimension, and not use some standard parts off the shelf? I haven't taken calipers to mine yet, but the sloppy steering has always been a complaint.
I'll try to take some time and get some dimensions tonight, and see what I can come up with.
