swatski
- North Caldwell, NJ
I've been newly inspired, lately, by @gmtech16450yz and other' postings on some novel ways to soundproof the boat. I myself have done many expensive and labor intense soundproofing mods... While I would say that several have proven reasonably successful - such as the RAAMat install etc. https://jetboaters.net/threads/another-soundproofing-thread-the-raamat-experience.11872/ - this new idea (here) is just crazy simple and yields crazy good results.
Of course - this most recent attempt started as something completely different, lol. I came across it initially when I was messing with my custom WakeMakers ballast install - I was fitting various bags in various spaces inside the hull and, in the process, noticed that some of those bags appear to attenuate engine noise...
Well, after some more experimentation - I can tell that stuffing "long" 350lbs ballast bags (inflated to the max with air) placed inside the back of the rear storage compartments (alongside engine bay bulkheads) cut the engine noise better than anything else I have tried, so far!!!
Crazy simple, too - basically, I'm using two older style bags that I no longer have other use for. Those are stuffed in the back of the storage compartments (pretty much dead space anyway) and inflated to fill in the space.
I will make some supporting modifications with foam sheets and and polyurethane, but even the crudest attempt yields astonishingly good results (relatively speaking of course).
Here are some (very bad pics) of the bags (those are inflated to the max, but sit inside larger outer cases).
Strbd:
And port:
I'll update during the week with some sound clips.
But - the difference is amazing. Such as simple mod...! I would say there is easily a factor of 2-3 drop in sound level during cruising. Unbelievable.
(I don't know to what extent the other soundproofing mods in my boat contribute to this latest success, but I would think it would work well on its own)
EDIT: Those air-filled bags would be used for regular cruising etc. only, and then deflated and removed for storage when rigging the ballast for surfing, of course.
Strbd:
And port:
