Blown motor
CarsonMason
Jet Ski
Sorry I'm new here and new to jet skis but have a question and hoping I could get some guidance, I bought 2 Yamaha skis brand new last year each have around 10 hours max on them. I put them in the water and one ran for a few minutes and shut of and wouldnt start back up, so I took it back to the dealership and he pulled the plugs and said we flushed it wrong and it would be 6 grand to fix it..does this sound legit?
Cobra Jet Steering LLC
Vendor
Florida
If you did it wrong and water went into the engines yes but get a second opinion . Never have the flush water running into the engine if the engine is shut off
CarsonMason
Jet Ski
Is there any other circumstances that could cause this? I feel like I did flush it correctly and that there is another issue, but maybe not?
Vendor
Florida
Anything is possible so try to get someone else to look at it if you did not leave the water running with the engine off and that takes a few minutes for the water to fill up the exhaust system and then get up into the engine also towing one with the engine off canl do the same thing
JeffVans
Zion Crossroads, Va
@Cobra Jet Steering LLC I have wondered about if you're doing about 45-50 mph (or 70 mph on a ski) and the engine (s) die, would that be enough to screw up your engine(s)?
Vendor
Florida
no I seriously doubt it
Vendor
Florida
The original poster did not really give detailed facts about the situation so it is all subjective
Vendor
Florida
another possibility is the ski was rolled upside down in the water and it ingested water from that, rolling it back the wrong way can do it.
Another possibility would be the engine ran hot and warped a head or blew a head gasket
CarsonMason
Jet Ski
I gave all the details I have, they both ran fine one weekend and the next we put them in the water and it started I put it in reverse and backed out and when I switched to drive and hit the gas it immediately shut off, unless a neighbors kid hooked up the hose and let it run it was flushed properly.. but somehow water got in the motor and it's a mystery, the Yamaha dealer said it had to be flushed wrong for this to happen...with less than 10 hours you would thing the dealer you bought them from would try and help out...I have it scheduled to let another dealer look at it, I will report back when we see why this happened...thanks for the ideas on what could've happened.
swatski
North Caldwell, NJ
If the engine hydrolocked due to flush water intrusion it really wouldn't start, would it? Is this a 1.8 or a MR-1 ski?
CarsonMason
Jet Ski
It's the vx deluxe high output 1.0
MidnightRider
Zumbro Falls, MN
Malibu
Wake
I agree with @swatski, no way a hydrolocked engine would start up and run before it died. Or a better way to say it is when an engine hydrolocks it doesn't start, it hydrolocks from being turned over - no? If it can, someone please educate me.
swatski
North Caldwell, NJ
That would basically rule out the timing chain issue (breaking in some 1.8s).
Any chance there would be water in the engine bay that would be sucked in after start, for example due to rain or due to exhaust cooling clamps falling off?
Cody700
PWC
Has the ski been frozen? This doesn't add up to me at all. If you had it running and it locked up when it was put in forward, it sounds like you took something into the impeller and locked it up. I have had that happen, sucked up a rock and locked it tight. Pulled the nozzle and replaced the impeller and all was well. There is more to this story it seems.
bronze_10
Raleigh / Wake Forest Area..
If it was under power and suddenly ingested water it is possiable it bent a connecting rod ... water doesnt compress like air does.
