Engine compartment-water
Ferg Dog 10
New to boating so please excuse any ignorance! 2017 Yamaha AR190. Last time out had a decent amount of water in the engine compartment. Bilge was on, drain plugs in, drain out port secured, etc. All hoses seem to be connected and I can’t see any leaks. No idea where the water entered from. I know a bit of water is normal, but this seemed excessive.
Decided to start by swapping out old drain plugs. In doing so, stuck my finger in the hole where plug does in ski locker and there’s water there. Same with the one next to the fuel tank.
Is this normal? If not, does anyone know how to solve the problem? Any ideas as to how/why there was a decent amount of water in my engine compartment? Thanks in advance and hope some of yall can give this newbie some help!
Dave burke
Near Lake Placid
Welcome.
Lots of posts on this issue. I'd suggest you look in the FAQs or use the search or advanced search functions, I've used them many times and they work very well.
Fortunately for me, I've never had this issue to any degree. I can tell you that water does accumulate in the bottom of the hull under the clean out port cover. I added a second bilge pump there several years ago which could be one reason why I've been lucky. I can find the post on this topic if you're interested.
Ferg Dog 10
Welcome.
Welcome.
Thank you Sir!
zipper
Boston Whaler
Are you trailering or are you at a dock? Easier to get all the water out on the trailer. Jack it up all the way, on a block of wood to get all the water from under the ski locker. The hull is at its deepest point below the ski locker and the connected bilge holds a lot of water there. You gotta get the bow up. The bilge pump in the engine bay is mounted over a hole that connects it to the bilge below. Water should not be normal. There are a few ways it can leak in. Lots of leak finding threads here on a search. Welcome.
Ferg Dog 10
Thank you! Will get the bow up on a block. Appreciate the advice!
HawaiiBreeze
Oahu Hawaii
Not enough info in your original post to eliminate or expand on BUT the first place to check is back at the drain plugs. They have to be more than than just twisted in. They have to be tight as tight as you can get them with your hand. Even the smallest opening in the threads will allow the smallest amount of water into the bilge and over a day of being in the water it will add up. I chased my own years ago and that's all it was. Sometimes now to unscrew them I use a crescent wrench for that little extra leverage to unseat them. The next thing is an anchor locker that is draining into the ski locker (they're built to drain to the locker) which doesn't have the drain plug installed and during wash down the water makes its way to the bilge area.
Good Luck!
sunbyrned
Louisville, KY
I had water coming in from a clean out tube that was not seated correctly. Basically, the tube where the clean out plug goes into needs to be secured at the top and bottom with hose clamps. If you look under the hatch, you’ll see the tube. Check to make sure the clamps are tight and are at the very top and very bottom. I hope this makes sense.
David Martin
Punta Gorda
Might be water draining from the engine hatch seal.......... everytime I open my hatch water drips off onto various engine areas
