4x15mph
- Downingtown, PA
I was on the river and after a bit of boating and floating, I started the 2 engines and found that the starboard engine would not rev over 2,000 RPM and it was making a muffled sound. I figured something was stuck and tried the remove technique a couple of times without any luck. I was right near the dock and we were planning on leaving anyway. Also, when I reached in the cleanout plug, I felt very rough plastic edges and burrs which made me think my new plastic liner was in pretty bad shape. I retrieved the boat using the one engine figuring I would look at it when I brought it home. I pulled the jet/impeller to inspect and my plastic liner looks to be melted on the lip and it is pretty scratched up all around. I can spin the impeller freely so it is not hung up on the impeller housing liner.... maybe whatever was lodged in there came out on my way back to the dock??? Anyway, below is a picture of my liner. Is is possible that it melted due to overheating? Would the cooling water circulate in the liner and could it get so hot to actually melt the plastic? Otherwise, do you think this is the result of something being stuck?
Should I try to clean up the plastic burrs a bit and put it back together?
