Neutron
- New Bern, NC
Good to know that in 174 years i will still be able to get one for my antique.
Yea, thats why I went with the DST-810. I know its not dead-on balls accurate, but, again, it's close enough for me, and the alarm has stopped. And they are available everywhere, even Amazon. Hodges Marine has 8 in stock. Obviously its " use at your own risk". Its just nice not to hear that beeping every couple of minutes and have something to go by as far as depth. Looks like the OEM one's may not even be in this year, at least during boating season.hahah right. I’m not sure what to do. I checked man websites and not many really show the stock status like Hodges. Called and online chat all day out of stock and back ordered. Some are guessing in 4 weeks but we all know that’s probably not right.
if anyone knows where to get one ordered today please let me know
yeha true. I almost went that route, but I have a 18 LSE and dont need the DST. My understanding is the DST is, depth, speed, temp. I only have the DT, depth and temp. I get my speed from my GPS. I remember looking at the transducer on bottom of my boat, and nothing sticks out, its pretty flush. If I got the DST810, I would have the wheel "sticking" out. Not that its a huge deal, but wanted to try to get whats needed first.Yea, thats why I went with the DST-810. I know its not dead-on balls accurate, but, again, it's close enough for me, and the alarm has stopped. And they are available everywhere, even Amazon. Hodges Marine has 8 in stock. Obviously its " use at your own risk". Its just nice not to hear that beeping every couple of minutes and have something to go by as far as depth. Looks like the OEM one's may not even be in this year, at least during boating season.
@Neutron are you sure about right and wrong here? I might be guinea pig to test this as I cant find the "garmin" version. Other than diff skus, it appears they are possibly the same unit? one is garmin branded, one is airmar. Unless you know something specifically different and curious why you stated this?
Like i stated before, there is no confirmation that the other part number will work. If you want to be the guinea pig, by all means go right ahead. I have seen that number available a lot, why? If it was compatible i would think it would be out of stock as well. I guess you could call Airmar to see what the difference is and if it will work but my gut tells me otherwise since its available@Neutron are you sure about right and wrong here? I might be guinea pig to test this as I cant find the "garmin" version. Other than diff skus, it appears they are possibly the same unit? one is garmin branded, one is airmar. Unless you know something specifically different and curious why you stated this?
ok good. Glad I asked.Like i stated before, there is no confirmation that the other part number will work. If you want to be the guinea pig, by all means go right ahead. I have seen that number available a lot, why? If it was compatible i would think it would be out of stock as well. I guess you could call Airmar to see what the difference is and if it will work but my gut tells me otherwise since its available
I will admit I’m starting to get confused on this thread! LOL… What’s the difference between the DT800 (010-11105-00) and the DST-810? My additional question is… If my boat does not have a digital display screen but rather has the old-school round dash mounted gauges… Will these Garmin aftermarket replacement transducers still show depth on the round gauge? I have read that these transducers work in conjunction with a Garmin app that shows depth. I don’t want to have to keep referring back to an app on my phone just to know depth. That’s too much going on at once while trying to drive the boat. My additional question is… If my boat does not have a digital display screen but rather has the old-school round dash mounted gauges… Will these Garmin aftermarket replacement transducers still show depth on the round gauge? The reason I ask is I have seen that these transducers work in conjunction with a Garmin app that shows depth. I don’t want to have to keep referring back to an app on my phone just to no depth. That’s too much going on at once while trying to drive the boat. The reason I’m not sure if this works with the old-school gauges is that from looking at the packaging of the Garmin transducer‘s… I do not see any wiring connections that match up with the “clip on“ connections that the OEM wiring has.Guys, my N2K error code popped up yesterday on both tachs! I have read through all these posts and am still confused. I have a 2012 SX240. Depth gauge, no wake mode and water temperature appear to be the only things not working. Will replacing this transducer with the 010-11105-00 fix that? It appears that this component is in the engine compartment. Does inmyElement or anyone else have more pictures from farther away showing the installed location of both ends of the defective or replaced transducer? I am not the handiest guy around but generally I can remove/replace something if I can see it! Thanks for all the previous research.
I called Airmar a day ago and their tech said that from what he can tell, the garmin dt800 and the Airmar dt800 should be the same. Both made by Airmar just garmen puts their own out there for some reason. He said as long as they are both Nmea2000ok, an update on my side. I purchased the other model number of the DT800 for my 18 242 LSE. This is the airmar branded transducer, not the garmin branded.
PN # 44-200-4-01 on the sticker on the transducer cable. Wish I knew the third digit meaning. It looks like our stock ones from yamaha are either 1 or 2 for the third digit. First w are the same, 44-200.
Customer Part #: DT820PV-235-N2
Top of the transducer looks the same. shows 20 degree tilt image and same numbers/airmar 20-635-01.
I have purchased the same NMEA cable and plugs right into this transducer as well. I have cut off my yamaha factory transducer connector and spliced this piggy back cable in prep to install this new one.
I plan to go down to my lake house next Friday and should get it installed sometime over the weekend and let everyone know if this works or not. wish me luck.
thanks for calling them. That's great to hear. I just went on a whim with this as I am no expert on this but def interesting seeing the numbers and pictures all looked the same. Have me feeling a little better about this when I hook her up. Especially since this is the only one I could find on eBay availableI called Airmar a day ago and their tech said that from what he can tell, the garmin dt800 and the Airmar dt800 should be the same. Both made by Airmar just garmen puts their own out there for some reason. He said as long as they are both Nmea2000
ya good point. The link is not working so check that want to see it. Idk if it’s called bus connector but would make sense if there’s an adaptor instead of having to splice thisMy 2019 242x was reporting errors connecting to the transducer and beeping non-stop this weekend so it looks like this will be my next project. Does anyone know if the oem transducer just uses a Yamaha engine bus connector instead of a nmea connector? It looks like you can buy a Yamaha engine bus to nmea patch cable https://www.westmarine.com/buy/garmin--yamaha-engine-bus-to-j1939-adapter-cable--19089283
