Lectrotab Trim Tabs
FloJet
Moore, Oklahoma
Is the powder coating for the fish? Other than trailering, when are they visible?
Yes just more for aesthetics. I'm sure someone will say it helps with something else lol.
hobineros
Cutler Bay, Florida
+5 HP for powder coating - reduces the coefficient of the drag of water across the surface of the tabs.:dead:
J-RAD
Orem Utah
Not to mention the acoustical dampening... :hilarious:
Bunch of smart asses in here...
FloJet
Moore, Oklahoma
GoVols01
College Grove, TN
So do the trim tabs aid in wake surfing or what?
J-RAD
Orem Utah
Not a bit. They help some boats get up on plain faster (Not an issue on our boats), they help smooth out the ride in rough water by putting downward pressure on the nose of the boat, and can be adjusted independently of each other to level out the boat if loaded unevenly.
FloJet
Moore, Oklahoma
ClemsonTiger
REJECTED / BANNED
REJECTED / BANNED
Jupiter, FL
You always have to keep tabs on your trim...
swatski
North Caldwell, NJ
@swatski should be able to tell you his experience on this. I believe he has tried this for surfing?
Generally speaking - no. Those might help shape the wake but actually the most important issue is to design and install the tabs in such a way that they would not interfere. Which is not trivial - with the crazy YJB transoms.
The directions to my install (from Lectrotabs) are kind of all over the place, but the design that I posted works extremely well - for both cruising and NOT interfering with wake surf.
EDIT: I was able to make small improvements in the wake surface by making very small adjustments with the tabs, but my boat is still not fully dialed in for wake surfing. So, I would not count on the tabs as an aid. Rather, make sure you can get those out of the way when you need to.
Beachbummer
Houston TX
The tabs also help plane at lower speeds, which can help greatly on bad chop.
ClemsonTiger
REJECTED / BANNED
REJECTED / BANNED
Jupiter, FL
Yes, what are these mysterious devices labeled “trim tabs” that have been around since the 50’s and what is their purpose....?
FloJet
Moore, Oklahoma
FloJet
Moore, Oklahoma
The main advantages of tabs IMO. I was thanking myself last weekend for having the tabs. 30 mph winds and she was cutting thru the waves nicely on low speeds.
swatski
North Caldwell, NJ
Well, of course. But the confusing factor with jet boats is - there is no trim like with o/b etc. Since Yamaha has not offered any trim aid from factory, not even sponsons like in jet skis, this can be a confusing topic.
The transom has crazy-a$$ shape and angles which make it very difficult to squeeze something in there that would work. Some people also may be concerned about changing the intake angles when trimming, etc.
ClemsonTiger
REJECTED / BANNED
REJECTED / BANNED
Jupiter, FL
I was just messing about.
Chris Evans
Anyone know if the swat ski set up will fit on the 2011 242 Limited S? Any recommendations to this boat for the tabs?
zipper
Boston Whaler
It will help you visualize, get an idea of size and placement if you make a cardboard cutout of various sizes and hold them up to the transom. It helps to make sure you do not interfere with the tie-down straps.
