Post pictures of stuff found in your jets
At the end of Memorial Day weekend I found all of this
Last night this Lego forced me to pull out of the channel and use a clean out plug
txav8r
Lake Ray Roberts, Texas
LOL...I discarded the evidence. No pics! And I am absolutely not admitting to sucking up my own cigar butt! :muted:
txav8r
I did hear that a former forum member sucked up a condom! They don't process well through the pump! But you gotta give it to the guy!:winkingthumbsup"
WickedPorter
Polk City, IA
This little guy disabled my starboard motor the other day ... wedged itself on to one of the blades.
KXCam22
Kamloops BC
MNdrifter
Rochester, MN
Skysurfer2010
Philly
I hate to admit it, but I find it humiliating when I have boating friends on board and I suck something up. Then I go to the clean out plug and after cursing and prying for 5 minutes I pull out a 2" twig. They look at me and are like, "that twig caused a problem?"
sysinu
Park City, UT
Amen to that. I sucked up a water bottle cap at Rainbow Bridge (at LakePowell) right after I left the no wake zone and before I could get it dislodged from the impeller, a tour boat (Canyon Princess... it's like 25' tall, 70' long, 20+' beam, steel hull, diesel dual screw) come through and nearly put us into the wall. I felt stupid something that small could cause such a big problem.
Had I been monitoring channel 16 and 9 like I normally do I would have known the tour boat was coming and I would have kept her under low power on the "good engine" to keep us happily maneuverable, but when there's high runoff, I get so much stupid crap in the impeller it's no fun to go into any bays. 2" twigs aren't my usual though - most of what I picked up was "I had too much Mexican food, turd sized" twigs that are 4" or so and about 3/4" thick on my lake.
Yamborghini
Daphne, AL
You'd think a 6000+ rpm impeller would treat twigs like a ninja blender.
@Bruce Legos are stronger than steel.
billyb
St. Louis
Limited
This was my first...
And a week later, I had to travel 90 minutes on a holiday weekend in the main channel at the lake of the ozarks on one engine at 5 mph back to my dock. After putting her on the lift, I found absolutely nothing in either engine. I put her back in the water and she ran great.
Question: when your engine starts but does ZERO rpm...you have something stuck right?
I am not looking forward to my first rope. My buddy sucked up a corn cob.
Boat Crazy
Lebanon Missouri
When your engine starts and no rpm is what I would call, I thought it started. Has happen to me several times.. Cavitation is high Rpm's and go no where. Will get a high pitchy sound and maybe some vibration.
Boat Crazy
Lebanon Missouri
Wow, being on LOTO with just idle speed would have me stressed, especially on a holiday weekend. Glad everything turned out ok.
KXCam22
Kamloops BC
I explain to my passengers that a jetboat is much like running two huge hoover vacuums across the lake. You are bound to suck up something. Cam.
jdonalds
Redding, CA
It's true a tiny twig can take the fun out of a day of boating. This, in my opinion, is the one thing about jet boats that a prop boat won't suffer from. Fortunately for Yamaha owners there are clean outs.
I wonder if Yamaha has the design locked down with patents which is keeping other boat manufacturers from including clean out ports? For my money there are some interesting boats coming onto the market from other companies but the lack of a clean out port would present a major hurdle in my decision to buy a non Yamaha boat.
Boat Crazy
Lebanon Missouri
I think I read some where that Yamaha has a patent on the clean outs until somewhere around 2021. I can not seem to locate that source at the moment.
Boat Crazy
Lebanon Missouri
While turning around to pick up skier I heard a ting....ting....ting noise. Impellars sharpened it like a pencil. Too long to pull through from the top. I had to push it out from the bottom and allow to float out from bottom of boat.
If your engine starts and continues running but the tachometer is showing 0 rpm then you have a bad tachometer or sensor. The impeller is directly driven from the engine so if the engine is running the impeller is turning.
Cavitation caused by something stuck in the impeller will cause vibration, noise and lack of thrust.
Why boat back to the dock instead of throwing anchor, shutting down the engines and cleaning out the debris?
billyb
St. Louis
Limited
Yeah, it was a challenge...
I tried the backup thing a few times and that did not clear it. So I shut down the engine and proceeded one one engine at 5mph.
The loa is VERY, VERY busy on a holiday weekend. Anchoring in the main channel (if the 100 foot of line would have reached), may have snuck my boat. Very, very large boats frequent the main channel with reckless abandon in the main channel of the loa on a holiday weekend.
I was just shocked that it had relieved itself on the journey back.
