Rumble at idle speed.
Terrance
Porters Lake Nova Scotia Canada
Glastron
GT
Hey all Glastron Gt187 jet boaters. Just checking out if you all experience a rumble at idle speed, that goes away under minimal power and higher power?
McMark
Monongahela, PA
Don’t have a Glastron but the Yamahas do that also.
BobbyP
Glastron
GT
I haven’t experienced that...
Floyd
Tampa & Maine
Impulse
I haven't heard that. Does the rumble sound louder with the engine hatch open, or is it resonating forward in the hull?
Cobra Jet Steering LLC
Vendor
Florida
The amount of water in the muffler , more water makes it quieter less makes it louder. An obstruction in the water line can do it even a slight obstruction
Vendor
Florida
Also if you run your engine on the trailer without water going to it, you reduce the water level in the muffler so you should notice the engines are louder when you first put the boat in the water and after a few minutes the noise level should quiet down somewhat . I also believe that the water level drops at planning speed so this also contributes to the louder engines people dislike. Sea doo had variable valves that changes the level of water in the mufflers at speed It has been years since I owned one so I forget the name they gave it but it looked like the top of a rave valve as it operated off engine vacuum back by the muffler and I believe it was adjustable also.
BobbyP
Glastron
GT
Make sure the black strap on your exhaust resonator is still on...
BobbyP
Glastron
GT
Yes. It’s big, black and plastic.
Terrance
Glastron
GT
Well what do you know. The black 20 inch rubber strap was split and it is not attached. Do you know what the strap attaches to? I am trying to find the part number for the rubber strap or a good replacement???
BobbyP
Glastron
GT
It attaches to brackets on both sides of the resonator...The part number is on the strap.
Terrance
Glastron
GT
Hey Bobby... Thanks for the reference. I purchased the same strap from the Seadoo shop locally today. I appreciate your replies and help. Cheers!
BobbyP
Glastron
GT
No problem! If you picked up a new strap, it might be hard to get it on, I stretched mine out for 24 hours and it made it easier.
Terrance
Glastron
GT
Hey Bobby. Got the rubber band on the hooks. You were right. A tough fit for sure. The good news is it did quite down the rumble back to where I remember it to from new. Thanks again.
NavyShooter
Windsor Junction, NS
Glastron
GT
Got a picture of where this is on the engine? I'm curious now....something for me to look at over the winter.
I brought my boat in today. :-(
