@Paulie There wasn't much grease around the bearings actually it all seemed to be in the cone. I cleaned out what I thought was good put the new grease in the cones then reassembled. I also installed new O rings from the dealer. I just used a rag to wipe e'm down as best as possible. No air or special solutions.
I also brought home some Lithium based Moly grease. I changed my mind and ordered Honda Moly Grease which will be here Friday to get her assembled before the weekend. I also ordered a tube of Yamalube Molybdenum Disulfide Grease which will be here a week from Friday for future usage.
Do dealers not carry that grease? I know it may be cheaper to order it, but I don't hate my local dealer so I don't mind buying stuff from them. Just wondering.
Your Yamaha dealer has all of the supplies you need. That is the same place I get mine! I don't know why so many people try to save a few bucks, but they end up mixing greases that are not compatible to save pennies. Just buy what your manual details and you will be fine.
This is true depending on how you look at it. My closest dealer, one of the largest in the world, does not carry yamaha fogging spray, and a few other basic things which I don't recall at the moment. They do carry fogging spray, just not the yamaha stuff.
Dang, Yamaha doesn't even have their own stuff. I had the same issue when I bought the new boat. They had it in bulk of course, but didn't have tubes. They ordered it for me though.
@Bruce I found this as an alternative to the Yamaha grease. It sounds like it is very similar to both the Loctite 567 and the Permatex thread sealant. Do you think it could be used for both the driveshaft spline and the impeller threads?
Curious what area we are looking for grease, is it for the cone on back of impeller? My manual says EPNOC AP #O lubricant or equivelant. Can not find the EPNOC so not sure what is suppose to go in the cone area.
The same day I put up this post I sent an e-mail to Exxon. I thought everyone else might be interested in what they have to say.
I told them I had an application that required EPNOC Grease AP #0 and I asked them what it was and which of their products would meet the specification. (By the way they also own Mobil oil.) Here is their answer:
__________________________________
According to information at hand:
EPNOC GREASE AP 0 is an extreme pressure multipurpose industrial grease designed for applications where heavy loads, shock loads, or water contamination are present. It is a lithium soap grease incorporating extreme pressure additives and a well refined, high VI oil.
Depending on the application, Mobilux EP 0 or Mobilux AW 0 are suggested.
If you are replacing your impeller, I know the manual says to use the lock tight 567 on the impeller, however the dealer mechanic told me they always use never seize on the impeller threads. And after I had problems and ruined a shaft and impeller . I tend to agree.
Loctite 567 isn't a thread locker, it is a sealant to prevent transfer of fluid/oil/grease. Here is the info from Loctite's website.
"Loctite® 567™ PST® Thread Sealant is a general purpose instant sealer for tapered and straight/tapered fittings. With excellent solvent resistance, it can prevent galling and withstand temperatures up to 400° F (204°C). Excellent for high pressure applications: locks and seals tapered metal, pipe threads and fittings. It is ideal for stainless steel, aluminum, galvanized metal and other inert metals. Disassembles with hand tools.
Loctite Thread Sealants
Thread sealants prevent leakage of gases and liquids from pipe joints. All such joints are considered to be dynamic due to vibration, changing pressures or changing temperatures. Loctite anaerobic sealants cure to insoluble tough plastic thread fillers which prevent leakage regardless of the torque applied."
I expect with its teflon type thread filling, that it gets sticky and hard to get the parts apart regardless if it is a thread locker or not. There are good anti-seize products out there, and I get why techs would start using anti-seize, knowing how many have had issues getting the impeller off the dang shaft. And I am wondering why a sealant is needed in this area myself. I just wanted to post that Loctite does make other products than thread lockers and this is one of them. I am sure it is more waterproof than anti-seize...here is what permatex says about their products. This is the standard anti-seize you get at the autoparts store...
Here is an available all copper version of it, what I use all the time for spark plugs and wheel lugs...
"A premium quality copper anti-seize and thread lubricant that may be used to prevent seizing, corrosion and galling where high temperature conditions exist. Contains a high percentage of micro-fine copper flakes in a semi-synthetic grease carrier and is fortified with high quality rust and corrosion inhibitors. Temperature range: -30°F to 1800°F (-34°C to 982°C). Provides good electrical conductivity. Meets Mil Spec #907E. - See more at: http://www.permatex.com/component/virtuemart/permatex--copper-anti-seize-lubricant-detail#sthash.9qvRPJ5w.dpuf"
What I find interesting is that the anti-seize compounds are only water resistant, not waterproof. That said, the statements made by Loctite, don't say "waterproof" either. But they do say that they will seal pipe threads from leakage of gases and liquids from pipe joints. So I don't know for sure, but I tend to think that a Yamaha tech may do things to make his life easier, not to make your wallet stay full. I wonder if there is a Tech bulletin out on this?
@txav8r Mel - so thread sealant/anti-seize for the shaft and impeller, If I follow correctly.
But what about the pump bearings, in your opinion? I, for one, am not sure one needs high heat-resistant grease for that cone. Rather, these bearings are at risk of water intrusion if a cone leaks. I still think that the magic Island Racing type of slurry maybe the way to go. Many make it by mixing marine grease with a bit of gear lube in a bowl.
@swatski , I can't advise but if I were doing any of them, I would use the recommended. If I couldn't find them, I would go to my Yamaha dealer and get them. I think the main issue is they only have some of these lubes in bulk.
Purchasing lube for the bearings (cones) sure is frustrating. Oil only: (readily available but probably need a port to get enough in). Slurry: difficult to ensure compatibility between oil, grease and any residual grease (what brand/spec/weight and where to get both is still hard and a lot of guessing with compatibility. OEM AP#0: good luck finding it. Island Racing is looking better just for convenience. Just venting...
Until you see their "online" ordering system. Best of luck. I attempted to place an order on Wednesday night and haven't heard a word from them.
Oh and per their website, DON'T call them regarding your online order!
I assume I won't see that order, so I will probably just use gear lube.
