Sportjet 120 - Rectifier
palessard
Hi folks
I understand the rectifier is bad on these engines.
Luckily, mine has no ignition trouble yet, but I'm considering a preventative swap of the rectifier. This thread: https://jetboaters.net/threads/sport-jet-force-mosfet-rectifier-regulator.16219/ seems to mention that we can swap the rectifier for a jetski one.
Now I'm an apprentice mechanic and the electrical part of things kinda boggles my mind, so I'm not too sure what to look for exactly. I understand @Cobra Jet Steering LLC linked to a Yamaha Waverunner 1000 rectifier. Would this part fit the bill? Regulator Rectifier for Yamaha FX1000 Waverunner 1000 2007 2008 FX1000 | eBay
Also, does anyone know how to connect everything back together?
Thanks for the help and happy boating.
Beachbummer
Houston TX
I would look at something like this instead, where the wires are in place so you can splice easier.
There are some Jetski ones that also come with the wiring already in place for Seadoos.
Best of Luck!
palessard
Thanks for the quick reply. I ordered the part you linked, hopefully it'll make this engine a little bit less troublesome.
Vendor
Florida
yes look for 3 yellow field wires a red power wire and either a black ground or a grounded case those will also make your battery last longer because theY regulate the charging voltage to the battery
your system has 3 -2 amp fields so not sure what that one has but you need all 6 amps.
