Trailer bunks broke what's the best wood to replace the old stuff
robert843
Myrtle Beach, SC
@HELP ok so went to pull the boat out and thank god I walked up to get truck as the crew with me today would have just backed it down and it would have been a disaster! I'm in a time crunch as with it being a holiday weekend I can only leave my boat in the wAter where it's at tonight. What is the best wood to use from home depot or lowes also is there a carpet I can get from there that will work? I'm going to replace all if I can get the items I need tonight. I guess I need the wood, carpet, stainless staples and screws I also think I saw I need underwater glue is that correct? If I'm missing something let me know.
Murf'n'surf
Naples Florida
Go with pressure treated lumber for sure.
Home Depot should have a cheap Berber carpet. Berber is the best to use because the fibers don't seperate under load and expose the crusty backing. Berber will require a longer staple and most likely a power stapler.
latitudeadjuster
Mineral, Virginia
They have that porch carpet you could use...but a good stapler until you can do a better job. Did someone steal the board??
Murf'n'surf
Naples Florida
Yes to stainless staples.
Glue is not necessary but might help during installation. Look for spray on 3M adhesive glue.
Do you have a west marine close by? They stock bunk carpet.
robert843
Myrtle Beach, SC
I do but they close at 5pm. Any specific pressure treated wood I should get or it doesn't matter?
Murf'n'surf
Naples Florida
There's really only one choice of pressure treated in the size you need.
Make sure you have all of your lag bolts still.
latitudeadjuster
Mineral, Virginia
@Murf'n'surf correct...if you have time, fit your pieces and do correct ...if in a pinch...make board like other side with whatever cartpet....you can take your time at home making correct and install next launch....wow...glad you noticed that before load
Andy S
Chapin, SC 29036
Cobalt
kiln dried would be the best, I think Home Depot carries it but for a quick fix any pressure treated wood will work.
robert843
Myrtle Beach, SC
I do not deal with lumbar a lot so I bought 2 x 6 treated wood but now that I've got here the tag says 2 x 6 treated but it's is actually .5 inch short on all sides is that because it's treated?
Murf'n'surf
Naples Florida
Why kiln dried?
Doesn't kiln dried have less flex than treated? Doesn't it absorb water sitting outside then rot?
robert843
Myrtle Beach, SC
Murf'n'surf
Naples Florida
All boards are smaller than their names. That's normal.
latitudeadjuster
Mineral, Virginia
It will work to get your boat loaded and home....get correct stuff for next launch and replace...start thimaking about replacing all the boards.
I think is odd if nothing is remainin and still asking...did someone take it for their needs??
itsdgm
Andy S
Chapin, SC 29036
Cobalt
Why kiln dried?
Kiln dried treated wood won't shrink like regular pressure treated and typically will hold a lag screw better. For bunks, shrinkage might not be a problem .
robert843
Myrtle Beach, SC
No I had taken the last bolt out and removed it. It was half hanging off missing two bolts. I'm replacing all now and going to do it correctly and just be done with it my local Walmart stocks bunk board carpet so I'm going to grab it and use it. I figure if I got the boat off might as well do it all. How anal were you guys about making sure they where back on and the spacing between boards was exactly the same? I have replaced the rear two starting on the two center boards. The actually look pretty good almost was going to leave them out of laziness lol but I'm pulling them as well ugh
Andy S
Chapin, SC 29036
Cobalt
As long as your vertical supports haven't moved, which I doubt they did, mounting the boards on the supports will be fine even if not is the exact same location as previous boards.
robert843
Myrtle Beach, SC
Mine are all welded to the trailer if they move its time for a new trailer lol. Thanks @Andy S you just made my project a little quicker
robert843
Myrtle Beach, SC
Thank you @Murf'n'surf @Andy S @latitudeadjuster @itsdgm putting the tools away now I really appreciate the quick responses to help. It was a frustrating project as I had to do it by myself and all by hand since I couldn't find the drill bit I was looking for but one less thing to think about now. Only positive is I left the boat in the water in a slip so I guess no excuse not to go out tomorrow now. I had planned to do this in the off season I guess I will replace this project with replacing the leaf springs this off season ugh. By then I will basically have a new trailer as I replace all brake pads, lines, rotors, and bearings already this year.
