WaveRunner Dive Shaft
CanTex
Spring, Texas
MasterCraft
Long story short...friend used waverunner, sucked up rock and trashed impeller and wear ring.
2009 Yamaha FX SHO model
I've successfully removed and replaced the impeller and wear ring. Now at the final stages of re-assembly I cannot get the jet pump assembly a fully install (impeller shaft appears to be binding on the intermediate shaft...some how!!!)
Actions / Knows:
* The splines on the impeller shaft are mating up with the intermediate shaft
* Impeller shaft was cleaned, no burrs or damage to splines, and re-greased
* The last 0.5" - 1" of impeller shaft will not seat on the intermediate shaft (not caught on alignment pins)
* Ran an inspection scope through intermediate shaft...no visible damage or debris
* Rotated engine by hand (using big nut on back side of impeller), not binding rotationally - bind appears to be on longitudinal axis
* Had my wife help with installation, I rattled and giggled the impeller shaft from the intake grate and she was gett'in on it - still no luck
* After multiple attempts it binds in same location
Questions:
* Is it likely that the intermediate shaft got out of alignment during the "rock incident"?
* Do I just really need to get after it? Video's I've watched show that once the splines are aligned it goes in with ease.
I've posted on this forum as the jet pump units are near identical for the waverunners and jet boats.
Thanks in advance, any suggestions or tips are greatly appreciated.
Murf'n'surf
Naples Florida
Did it come out easy?
You don't have so much grease in there that its causing it to stop, right?
I've had that problem 2 out of the 5 times I've pulled the impellers on the boat,
sitting at the back of the boat wondering what's not working correctly, it can't be this difficult,
after numerous attempts and sometimes some force (if I remember correctly) I get it reassembled,
Murf'n'surf
Naples Florida
Same....I had to tap a little with a hand sledge but ya gotta be careful :)
CanTex
Spring, Texas
MasterCraft
There was factory adhesive between the impeller pump housing and the transom plate, after the adhesive gave way removed with ease.
Grease...on first attempt at reassembly l I did liberally coat the impeller shaft splines. When I ran the inspection camera through, didn't appear to be clogged with grease.
appreciate the input and ideas.
CanTex
Spring, Texas
MasterCraft
So ya'll gave it some love with a 5lb mallet...the engineer in me always struggled with the 5lb solution!!!
thanks again, I'll wack at it between conference calls this afternoon!!!
Murf'n'surf
Naples Florida
Double check that you aren't getting hung up back at the pump somewhere then wack (lightly) away.
Cobra Jet Steering LLC
Move the intermediate bearing vibration dampener back and forth a bit so the splines slide back in, sometimes they get worn and have slight recesses in them that hang up when you reinstall it.
Isn’t it ironic that with all the tech available the right tool for the job is a hammer?
