- Northern Vermont Lake Champlain
- Boston Whaler
- Other
4/9/18-We had Capt. Stan Walker perform a marine survey on the above 1991 Beneteau FIRST 35S5. http://www.marinesurveyorconsultant.com He goes thru all the systems on a boat, 120v AC, 12v DC, potable water system, raw water system, propulsion, prop., Cutlass bearing, stuffing box, rudder post and steering linkage. He goes over the whole deck and hull looking for moisture and hidden repairs with a phenolic hammer and a high quality moisture meter. The boat "sounded" dry with the exception of the cockpit aft of the binnacle where moisture was found. Two potential causes 1. Teak strips on the cockpit sole need replacing/rebedding and 2. The binnacle needs to be released and rebedded. A non structural bulkhead under the starboard cockpit lazzarette had some rot. That is what happens when your winter cover is only a loose tarp over the boom. The seller, who bought the boat 1 year ago had the marina winterize the Volvo diesel but did the boats water and drainage system himself. I HATE when people do not learn about everything on the boat after they buy it and then decide to try their hand at maintenance. He said he "winterized" the water and drain system with antifreeze which was visible in the port water tank and the bilge sump. But then I showed him the water tank in the bow under the v-berth half full, dirty and iced over. He looked at me and said he did not know it was there. The antifreeze in the bilge sump was ok, but he never energized the pumps to circulate the antifreeze thru the system. The freezing water broke both bilge pump strainers and possibly the float switch or one of the bilge pumps. Only one was working! The rudder needed the lower bearing rebedded or replaced. The lower bearings are known to come loose from their bedding. Dropping the rudder is the only fix. I have a long punchlist of small things in addition to cleaning, compounding and waxing, mod/ electronics install, 3 blade feathering prop. So looks like we may be buying a little more of a project boat than we thought, but I am up for it. She will be a nice boat when I get done with her. And some of the work can wait until she is back on the hard in the fall. Just waiting for Capt. Stan to finish his 30 page report tomorrow. Interested to see what fair mkt. value he gives her. Talking with him after the survey, it will be lower than the 40k value another surveyor came up with a year ago. NADA list her at $42k. I read his report before we made an offer, and he missed some things. Will have more info tomorrow when we get the report. In the mean time here are a few pic. taken at the survey.
cockpit
broken bilge pump strainers
2 bilge pumps
rotten bulkhead non structural
thru hull transducers for depth and speed, replacing one with forward scan sonar transducer.
I look at this and shake my head, WTF. Definetly going to fix this mess forward of the mast.
the keel bolts and some epoxy paint patch work
![20180409_124813.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/71/71649-632b7c9563177e8f995c2737f332833c.jpg)
lead keel good with a draft of 6'5". Air draft is just under 52'
I dont mind working on stuff and maintaining it right, after all we are "buying our second sailboat, FIRST.![Winking Thumbs Up :winkingthumbsup" :winkingthumbsup"](http://JetBoaters.net/winking-thumbs-up-smiley-emoticon.gif)
![20180409_091346.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/71/71641-798adceded079d621407b03e7b9ea1eb.jpg)
![20180409_093537.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/71/71642-1c431b18b5fec035b29497b2eb1760ab.jpg)
![20180409_114151.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/71/71643-c931ab31342e24bf50212a403b179ebf.jpg)
![20180409_103103.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/71/71644-78f218f79d0308e2830f49fee663efd7.jpg)
![20180409_090604.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/71/71646-47c41108a83deb3555b87e0cf5536f39.jpg)
![20180409_091931.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/71/71647-f4722700fdb0878d393981e2b2a3bbba.jpg)
![20180409_124900.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/71/71648-633cf0f198077d9325afd5a5f54e5b11.jpg)
![20180409_090539.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/71/71650-93a0e53a05df8a89401a96beef734b16.jpg)
