Goodness, going into my third season working on this conversion. Snow in the winter time just isn't conducive to working on a boat that stays outside. Oh well, I said in the original post that progress would be sporadic, and that has certainly held true.
Anyways, I've extended the wiring for both engines' YDS plug-in to underneath the steering wheel. This is
much more convenient to be able to sit in the captain's chair and plug into YDS, as opposed to popping the engine hatch and having the laptop sit on the rear seat (YDS cable isn't long enough to reach from engine compartment to the captain's chair).
I have an electrical gremlin I'm trying to figure out on the starboard side motor. I think it may be related to my bypassing of the security box. The port engine behaves as it should: when I key ON, the fuel pump primes, and if I key OFF in the middle of priming, the fuel pump immediately stops priming. Which is how it should behave. But the starboard engine, when I key ON fuel pump primes, but will continue to finish priming, even if I immediately key OFF. It shouldn't do that. If I bump the starboard starter, then key OFF and go back to key ON, it does not prime again. I have to wait about 30 seconds or so (I can then hear the main relay switch off) until I can key ON again, and prime the fuel pump once more. Something is keeping the main relay and/or the ECU awake for about 30 seconds after I key OFF, which shouldn't be happening. Whenever I key OFF, the main relay and ECU should be immediately killed, like is happening with the port motor. The starboard start will engine and spin the motor whenever I key START, but motor does not fire up.
I swapped the wiring temporarily so that the port key operated the starboard motor. Starboard motor behaved exactly the same, so as far as I can tell, the issue is not with the ignition switch, or any of the wiring under the dash. Seems like it's probably wiring or ECU in the engine compartment. Examining the wiring of the security system bypass, everything
looks correct. But I may redo all the connections on the bypass anyways, just to make sure.
Once I get this electrical issue figured out, I will be ready for testing in the water.
![3CAB610B-3DDB-4359-91D6-EDF7B15B6A47.jpeg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/174/174037-1c46009f99be58d28b7fb7b75cef2706.jpg)
