The big thing stopping me from adapting the trim system onto my boat has been how do I actually control the trim? I've been trying to brainstorm ideas, everything from some sort of locking shift lever, to electric motors to control the trim ring of the nozzles.
The jet skis used the QSTS or "quick shift trim system" if I recall. You pull a "trigger" then set the trim by twisting the left handle bar, similar to how you twist the throttle. Releasing the trigger locks the trim in place, either -10, -5, 0, +5, or +10 degrees of nozzle angle. I don't have handle bars, so adapting the QSTS doesn't appear to be an option.
There's another thread on here where I believe the guy used a trim tab actuator to control the the trim of the nozzles. I think he had the actuators in hand already, so it didn't cost him anything to use them to control the nozzle trim. I'm not sure how much effect trimming the nozzles will have on the XR1800, so I'm looking to keep this conversion low budget. Trim tab actuators are a little pricier than what I want to spend.
After doing some research, I learned that some Seadoo boats came with what's called Variable Trim System, or VTS. It looks like an electric motor either pulls or pushes on the trim ring in the nozzle. It might seem a bit taboo to use Seadoo parts on a Yamaha, but I think adapting their electric trim motor might be the best option to controlling the trim system adapted to a jet boat.
Certainly open to any ideas if anyone has any.
![Seadoo VTS.png](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/185/185707-495b1d300b1cf429ea71f89ca96b62c3.jpg)
![VTS1.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/185/185708-8d20e8bb6dfe7ea5264e2a5e4fbf49a5.jpg)
![VTS2.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/185/185709-a6fd132d89de998907f95fe18dc5fea3.jpg)
![VTS3.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/185/185710-92e4a095450643e2d8eecf7fbb96b2e2.jpg)
