AR190 Engine Trouble
Nickcap123
Hey guys! First post but unfortunate one on the forums. 2021 AR190. 38 hours. I bought the boat with 8 hours on it a year and a half ago. Used it all last year no problems. Never towed or abused. Stored and winterized appropriately. Was having rough idling issues since the beginning of the season. No problem with top end power. After general oil change and fuel additive thinking it was stale fuel, I could not get her running right. Fouled the first set of spark plugs after test ride. Took the boat into the shop and they are telling me i have 0 compression to cylinder one, and the other 3 cylinders are showing as follows: Cyl 2-180; cyl 3-185; cyl 4-185. With a boat with such low hours I do not know how this is possible. Any thoughts?? They are in the process of tearing down the motor to see the extent of the damage. Thanks guys for the help.
Buffalo, NY
That's really low hours to lose compression. Any chance you're still under warranty or have YES protection here?
Be curious to see what they find once torn apart.
jdkaeser
Cincinnati, OH
195S
I’d buy one of those cheap endoscope cameras that plug into your phone and put it down the spark plug hole. Try and see what is going on. If the piston doesn’t have a hole in it then at least you know you don’t have to rebuild. Could be something as little as a stuck or bent valve or bad head gasket. That low of hours it is shocking. Why did the guy sell it with only 8 hours on it?
Nickcap123
Just out of warranty. No YES warranty unfortunately.
Nickcap123
The endoscope camera is not a bad idea. Its at a authorized yamaha mechanic shop now. I gave them the go ahead to pull the head off but now thinking I should have done that, or a leak down test at least. I guess we will see what the damage is. The guy sold the boat after getting laid off soon after purchasing it.
