Ozark
- 195S
After placing the Riva Racing breather kit in my cart and seeing the nearly $50 total with shipping I decided to piece together my own kit. I believe these parts should work on 2012+ 1.8's. I spent just under $20 total for everything necessary.
The filter itself it is a Spectre 3991
The block off cap is a HELP brand part # 02250
You will need this 5/8 x 1/2 barb splice to connect the factory hose to the filter
You will also need a couple of zip ties
Amazon.com: Spectre Performance 3991 Black 9mm Breather Filter : Automotive
Buy Spectre Performance 3991 Black 9mm Breather Filter: Breathers - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
Everbilt 5/8 in. x 1/2 in. Barb Nylon Splicer Fitting 800239 - The Home Depot
Hose barbs are used with flexible tubing and the barbs grip the inside of the tube to create a seal. Use these nylon fittings for applications like water lines to tanks, garden hoses, lab equipment and
www.homedepot.com
