1.8l oil filter STP S3614XL
B0at1n
Little elm
Can anyone confirm this STP oil filter is acceptable?
This is what I can get local tonight.
I am going to do two oil and filter changes in the morning and then after cleaning out oil, I am going to put the K&n 1002 on with Yamalube but trying to save a few bucks for the 2 water oil changes.
There are those who swear that a higher quality oil filter is needed. I use whatever reasonably-known brand is the least expensive and readily available. I have done STP and Fram (mostly Fram). Boat is still running... I think you will be fine with the STP.
Thanks. This will get run for less than 5 hours and then changed so not worried about quality just as long as they meet minimum standards.
