ssommer10
Hello,
I just bought a used 2023 AR220 with 10 hours on it and all it needs was its first 10 hour service. I am going to change the oil and filters myself but a little confused. I understand using a pump to suck oil from the dipstick area as the main area and then removing the hose to suck oil from there as well and then maybe from the oil filter. My question comes to refilling, I will refill with what I removed. Is this boat a combination wet sump and dry sump? If so do I refill half the oil through the dipstick location and the other half on top of the engine with what appears to be the dry sump? Appreciate any help and thank you.
