FSH 210 Sport
- Tranquility Base
- FSH Sport
Okay,
A few weeks back I checked the brake fluid in the reservoir of the surge brakes… bone dry. I wonder how long it was like that since I’d never checked it before… boo on me. I’m still baffled at where the brake fluid went to. I know the brakes worked two years ago when the big Mule Deer Doe stepped out in front of me on the way to Lake Powell and I slammed on the brakes, the trailer started hopping and left big darkies on the road, damn that was close, my friend and his wife and their boxer dog were riding with me, he said nothing but his wife made a little squeak noise.
So, first thing I did was to put in brake fluid on the oft chance I could bleed them out and get by for a bit.. no das. I got old black fluid out first, the the newer fluid but it had air bubbles in it, and when I tried to manually pump the master cylinder I got lots and lots of little bubbles.. so bad master cylinder. After considering my life experiences I decided to just buy a new actuator, with the thought I‘d try and put a new master cylinder in the old one at some point and have a spare on the shelf.
While it did not help that I did this in the rain yesterday, it also did not help that there is nothing, and I mean zilch point poo poo about how to R&R this actuator in the instructions, did I say there was nothing instructions? Just want to make sure I drive that POINT home. First off, when you remove the big pins that hold that whole thing in, the wheels you can see In the pic fall out/down. Those pins also hold the guts in place, the master cylinder, the shock absorber etc…
You know, I just noticed that is there appears to be another removable plug on the bottom of the master cylinder reservoir.. huh.. why would you design something like that??? !!! I now have a plausible place for the fluid to have gone.
Have I mentioned yet that I’m not a big fan of surge brakes? That was before this escapade. One really good reason for having electric over hydraulic brakes is that you can use the manual brake bar on the controller in the cab to test your brakes each time you tow, this is a standard practice on my travel trailer, and if the trailer starts swaying you can apply the trailer brakes manually and get the sway under control. Finally, with modern integrated brake controllers being tied in with anti lock braking system, the anti lock braking system will also modulate the trailer braking to avoid wheel lock up and jack knifing.
Okay, what would have been really nice is if with the new actuator there were some wooden dowels that were only as wide as the actuator itself to hold the guts in place while you R&R it. I mean really, how much would a couple of freaking wooden dowels cost? What I had to do was to remove the folding part of the tongue, the safety chains etc.. and lay it upside down on my bench so I could remove the pins on the new actuator and then very carefully slide the new actuator into the swing tongue and then put the pins in. Even with me being very careful things jumped out of place and I had to hold my mouth just right to get things lined back up again. All of that could have been eliminated with two 5 cent dowels to hold things in place during assembly. Fuck. I don’t like to be negative but cmon.
I’m going to add fluid this morning and use a vacuum bleeder to pull new fluid through the system, and then my friend will be by later to use the manual pump on the actuator to do the final bleeding. I’ll try and get a couple of measurements for some dowels so that others can make them before disassembly/ reassembly.
Moral of this story, don’t be an idiot like me and not check the brake fluid for two years.
I’m also wondering how many folks out there have air in their surge brake system that causes excess travel on the actuator which makes for more slop when going from a stop to staring up again. Time will tell!
