FSH 210 Sport
- Tranquility Base
- FSH Sport
I had been eyeing the 19’ series of the FSH’s deck drains, @Can0n11 one on either side of the aft cock pit. I have found on many occasions that I end up with water pooling in the corners when out fishing or when washing the boat if it is not sitting perfectly level, so I decided to add two additional 1.5” deck drains to compliment the single center line mounted 1.5” drain. In addition to water pooling in the corners, I also wanted the extra deck draining capacity.
While I was adding the deck drains it occurred to me to get the rod holders that are right above the two aft storage areas’s hooked up to a drain so that when washing the boat water is not running down into those storage compartment.
I bought the L head drains from Marine East, and the Stainless steel scuppers from Gem Lux who makes most of the stainless hardware on the boat for Yamaha. The universal rod holder drain I bought from T-H Marine.
Where the thru hulls went through, there are two layers of glass, so I foamed that gap shut with water soluble sealing foam to make for easier removal if that need ever arises. We had to use a 3” hole saw to allow the nut on the thru hull room to be installed, the outside hole saw was 1.5”.
Big shout out to my friend Jim who‘s many years of marine experience and his help made this project possible.
Port side interior L head drain:
Port side exterior drain:
Port side internal plumbing: You can see the foam added in the nut area.
That vertical piece of clear vinyl goes up to the rod holder above this compartment:
Starboard side internal L head drain: Yes that is a rub mark from the hole saw.. future gel coat repair.
Starboard side external drain:
Starboard side internal plumbing: In this pic you can see where I added the foam.
We were not able to get the external drains in the exact same place on the port and starboard sides due to the internal stuff. I don’t feel bad about that at all since the OEM drains on the 19’ series are not the same from side to side either.
This project was about a pain in the neck, literally to accomplish but the juice should be worth the squeeze. Fun fact, I do not believe that piece of starboard in front of the live well comes out very easy, if you do this to your boat, just leave it alone and drill in front of it.
