FSH 210 Sport
- Tranquility Base
- FSH Sport
So, besides the fact the anchor locker hatch opens the wrong way, using the anchor is, well, a bit of a pain. So my friend who has helped me with the other projects came up with an idea and today was the first mock up. The bow cleat is only used really for anchoring, and the 6” pop up cleat is small for my 3/8” rode, so we decided to remove it and make good use of that spot.
Removed bow cleat:
Bow roller with wooden mock up adapter: The final adapter will be made of an aluminum block, but the wooden piece will serve as a good template.
Top view:
Once the anchor locker hatch is set up to swing to the left, deploying and retrieving the anchor should be a pretty easy affair. The quick cleat is rated for 500#. What is not shown is we are going to run a piece of aluminum flat stock from the bow eye mount on the inside of the anchor locker up the bow line and tie in with the roller mount on the back side, there will be an 8 inch standard cleat mounted on that bar that will be a place to tie off the rode to.
@Can0n11 @fatboyroy @lazergeek @bubbasuwannee
Removed bow cleat:
Top view:
