Leeder327
Hello Everyone!
I'm pondering adding a 2nd set of JL M880 speakers to my tower or switching them out to a pair of REV10's. Love the JL Audio sound but we want the sound to be louder at tubing and wakeboarding range.
Current Setup
2017 AR240
6 MX650's - 4 in standard spots in cabin and 2 added on swim deck. These are powered by a JL M600/6
2 M880's on the tower
1 JLM10IB5 in a ported box in the battery compartment port side
The sub and tower speakers are powered by a separate JLM600/6, bridged, so 200 watts to each speaker
Does adding 2 more JL M880's add more projection for tubing or wakeboarding? Does it make a big difference and is it worth it? If I did that, I'd probably get an M800/8 and use that new amp for the 4-M880's.
Or should I swap out the M880's, get a bigger amp and pickup some REV10's, keeping the MX650's in cabin and swimdeck? Are 4 - M880's at 200 watts each going to be louder than 2 REV10's powered at 300-400 watts each?
ALSO, I was not impressed with the infinite baffle woofer when mounted outwards in the port side battery compartment. So we put it in a ported box and that made a big difference. Is there another 10" sub that would sound even better or should I add a 2nd sub elsewhere? I'm not interested in infinite baffle usage and also don't want to take up alot of storage so it would have to be compact. That or maybe replace the 10" with a 12" in a box? But not sure if a 12" sub and box will fit in the port side battery compartment.. Would be nice to add more bass as well.
Current Setup
2017 AR240
