spatty99
- Orlando, FL
- Moomba
- Other
I want to add a bluetooth audio input adapter for my Sony CDX-HS70M stereo head unit (2008 212X). Ideally I would like to install a usb charging socket with volt readout (see amazon link below) in the existing audio input/phone cubby to power the bluetooth receiver only when the stereo is on (but not switched with the ignition).
Is there a way to grab switched 12v power only when the stereo is on?... Do I need a relay, and if so can someone link to something recommended on amazon? If a relay works, what would I connect to it? I'm already using the amp signal wire, would I use it too, or maybe the power antenna remote wire? The head unit manual is attached for reference.
Or is this overkill and full time 12v should be ok given the low power consumption (assuming I boat a minimum of once every 2 weeks)?
https://www.amazon.com/gp/product/B073NCMTQL/ref=oh_aui_detailpage_o02_s01?ie=UTF8&psc=1
