4x15mph
- Downingtown, PA
So here Is what I found out and it makes so much sense. I’m running a single battery and before leaving for the lake we had run a 12 Volt vacuum off the boat. Had no problem starting the boat before hitting the ramp. While on the lake we slowly made are way over to a spot and shut down the motor. We then did a quick high speed run to a different location. Once again shutting down the engine this time for about 2hrs. We had the radio on quietly. Go to try and start the boat and it would crank but not fire. According my Yamaha mechanic my Yamaha will not allow an ignition to occur unless there is enough battery power. The engine will crank but not fire. The fix is to run a separate battery for the stereo etc.. My issue is not vapor lock etc just low voltage. Today I ran it longer and also ran the blower.. Everything is now great again..
Did you add a 2nd battery?
