195S Depth Reading Incorrect Depth
C_4E
195S
Anyone have any issues with the depth reading being incorrect on the 195S? I was out this weekend and it was showing depths of 100’+. Every once in a while it would flip to the correct depth for 10-15 mins, then go back to the incorrect depth reading.
mpecoraro
Buffalo, NY
195S
@C_4E I may be seeing the same issue on my 2021 195S. I often boat the Lower Niagara River in NY and occassionally see depth readings of 100'+. I never gave it much thought...other than damn I didn't know the river was that deep. Your message got me thinking. I reviewed the depths of the Lower Niagara, https://charts.noaa.gov/BookletChart/14816_BookletChart.pdf. While there are a few 100'+ areas, most of the river is <100'. I will monitor it more closely the next time we are out and get back to you.
toddaltpeter
Ilinois
I've got an AR190. 90% of the time the depth finder is spot on. About 10% of the time I get a crazy 100+ foot reading or nothing at all and it just flashes.
Scottycamby
I’m having the same issue in my 21 sx190
toddaltpeter
Ilinois
Are you plugging a phone into the usb jack? I noticed that when I plugged my phone in yesterday the depth finder was acting wacky. When I unplugged it it started acting normal again. Not sure if it was coincidence or it it was causing some kind of interference.
dbfl
Port St. John, FL
Also '21 SX190... When I see those silly 100+ ft depth indications, it's briefly, and when starting to back away from a dock area. I chalk it up to the transducer dealing with bubbles or other turbulence. If you're seeing it other times and particularly if it's flashing, you could have a faulty transducer and/or mounting.
Smiley
Roswell, Georgia
195S
I had that happen when we were in FL on the Banana River of all places. It can get crazy shallow in a hurry out there if you get out of the channel in some spots. Turned the boat off then back on again and it seemed to stop.
